chris914
Oct 9 2004, 04:15 PM
What size tool do you need to remove the engine mount bar bolts?
tommy914
Oct 9 2004, 04:30 PM
I think mine are 17mm, for the big center one, on a 73 mount.
Cap'n Krusty
Oct 9 2004, 04:42 PM
The nut on the top side should be a 17mm, but may be a 15. The bolt wrench size is either 17mm or 8mm inhex (allen). The center bolts are 8mm inhex for the early bar, and a 13mm socket is used to remove the center nuts on the late bar. The Cap'n
sgomes
Oct 9 2004, 07:22 PM
The same size tool that you can use for anything on these cars...
