QUOTE(jim912928 @ Oct 9 2004, 07:38 PM)
If you were banging around on the pedal cluster...you most likely removed the bolts from the master cylinder? You might have a leak from the two supply lines from the brake resevoir.....they only push into to rubber bushings...drop the master cylinder and they can easily pop out or slip up just enough to leak.
This is exactly what happened. I didn't realize that they just pushed in. After reading some old posts I figured it out. I am planning on going through the whole brake system, don't think I am going to upgrad just yet, at this point the car will just be a weekend toy. But I do want it to be safe.
I think I will get a new master cylinder, where can I get one fo $100 so far cheapest I can find is $165.
Oh I also read in an old post about the resevoir lines, definitely going to do it that way.
sr
