QUOTE(groot @ Oct 11 2004, 10:08 AM)
How did you size your coolers? What made you decide on 2?
thanks,
After I decided on the location, I knew I had to split the coolers to make room for the exhaust , tranny, etc.
I had an idea that they shouldn't hang any lower than the stock valence (which I don't run anyway). Width wise, there was the limitation between not getting behind the rear tires and not getting too close to the exhaust.
I looked at doing heat load calculations etc but without real data on air flow capacity, etc. I thought it was just too academic. So if I have too much cooling (duct tape) if too little cooling, I'll fab some ducting to get the most cool air and the least hot air from the exhaust, motor,...
