QUOTE(ohh_jo @ May 16 2012, 06:28 PM)
Its a long red reflector that says porsche
The long red reflector sometimes has a tiny 1/8" hole near the center.
If it does, then get an old-style sturdy wire coat-hanger, and cut off a straight section of the coat-hanger about 10" - 12" long. Insert that into the hole in the reflector until you feel resistance. That resistance is the lock-lever inside the trunk, which is about 3" - 4" inside the hole. Use the sturdy wire to push in firmly on the locking lever. Be patient. It will probably take a few tries because this is your first time doing this. With practice, you will be able to do it very quickly.
When the lock-lever releases, the trunk will pop open an inch or so, because there's a spring attached inside on the trunk lever.
Forget all the advice above about buttons. That doesn't apply to you.
_
