QUOTE(Dr Evil @ May 20 2012, 02:10 AM)
There are some things to consider:
What is the travel of your clutch pedal?
What is the travel of your throttle levers?
If you can get these measurements, I can help with the design parameters for you.
The /6 may have used different length throttle levers so you may have to compensate for that. Your design can do this.
If you are able to change out your intermediate plate, I have several for sale with the pivot rod installed in them. However, this may be more than you want to do and there may be easier ways to get around this. I also have some pulleys that may work, but I need the measurements.
Hi Doc/Luke,
Thanks for chiming in Doc.
Clutch pedal and clutch is working 100%.
Accelerator pedal has full travel = 70mm, throttle travel at carbs = 30mm
Transmission is wevo'd 915.
Thanks for the pix Luke, I'm going to the shop later today and will take some photos of the current set up.
