here is some of our special prices that we offer to keep your car running at its best.
2.0/1.7/1.8 fuel injected tune-up $269.99 includes
(2.0/1.7/1.8 with dual carburators add $50.00 to synch and adjust carbs.)
valve adjustment, new bosch or ngk pluggs,new bosch cap and rotor, new bosch wires /Beru isolators, new boots, new bosch points, set dwell/timing, inspect all fuel lines and vacumn lines, check all injection components for proper function, vacumn/ohm test mps for proper function, clean battery conections and around battery tray, new anti corosion battery mat, service battery if aplicable, clean engine compartment, wash and wax exterior, dress all rubber, and rain-x treatment on windshield, vacumn interior.
2.0/1.7/(1.8 price only$699.99)
Major tune up and injection service $879.99
includes all the above plus+
compresion test and record readings, re-condition all 4 injectors, preasure clean and flow test, and instal all new rubber seals, new manifold gaskets, replace plenum/conector tube hoses, aux. air valve clean and test/ instal new preformed hose to plenum, new vacumn lines with contitech german braided vacumn hose, replace all fuel lines with german hp. injection hose, replace throtle body gasket, inspect cold start valve/ clean, new or rebuilt injection trigger points, check tps for function/wear and set to spec, check actual voltage at ecu/ clean all grounding points, new head temp sensor (1973 2.0 systems subject to higher cost if needed), inspect injection harness and boots, fuel preasure test.
extreme tune-up and fuel system service service $1099.99 all above plus fuel tank removal, hot dip tank, epoxy coat inside, refinish exterior, clean and inspect sending unit, install new micro sock filter, new hp fuel lines and clamps under tank, refinish strap, recondition evap system. clean under tank and report and treat any areas with rust with inhibitor chem treatment.
brake service all models $359.99
new front and rear pads, rotors turned, adjust rear pad clearance, bleed sytem and inspect, refill reservoir with dot 4 fluid
all new pins and clips
caliper rebuild service priced at
$ 99.99 front
$179.99 rear
master cylinder replacement
17mm parts and labor $299.99
19mm upgrade $349.99
901/301 transsmision specialist
first gear/reverse synchro hub and synchro band replacement with new oem parts $499.99
if slider is bad add $250.00 used or $525.00 new
complete transmission rebuilds available
tailshift to sideshift conversions at $989.99 installed
rebuild shift linkage $259.99
adjustments $49.99 includes linkage and clutch pedal adjustment.
rear trunk cup hinges replaced $299.99 all german parts
engine lid hinge brackets replaced $199.99
battery tray and suport replaced with oem quality parts $329.99 primed
hell hole minor repair $325.00
battery tray,engine shelf piece, and minor hell hole repair $ 939.00
rear trunk floor replaced $759.99 primed or painted to match 2 stage estimate given according to repair
all repairs involving spotwelds will be done by drilling out spotwelds so repair will be as was from factory in looks and function.
rotiserie restorations and complete ground up builds available.
free advice by phone for any questions regarding 914's.
for out of state and international buyers looking to purchase any pre 1983 aircooled porsche
we inspect, document and photo all pre purchase inspections so you know what your getting.
most dont know what to look for or where to dig...we are the best choice.
service starts at $159.99 plus travel time and expense...we are available at a short notice as we know that time is crutial to getting the good deal.
prompt reporting with our own wifi hotspot and mobile email and invoicing.
thanks
951-907-0362
- it's NOT ok to contact this poster with services or other commercial interests
View the full article
THIS IS NOT A 914WORLD AD!
Do not reply to this thread! No one is listening!
Click on the "View the full article" link above to go to the actual Ad!
