QUOTE(project914s @ Oct 10 2004, 10:05 PM)
Should I leave out the A/c when I put the 2.0 in the 1970?? Also is the 1974 2.0 have the emissions garbage on it ? or does it have the high compression 95 hp engine??
unless you *really* need the AC, leave it off, it'll save you some weight, a few HP and most of all, you don't have to cut up your perfectly good '70 body.
sell it (the AC) here or on ebay and offset some of your costs!
the '74 should not have any significant smog equipment unless someone added it to it later. as for the high-compression, none of the US cars had that, that was euro-spec.
altough, a lot of people have replaced their US spec pistons with euro-pistons, bumping up the CR. so, you might as well have euro pistons in your car.
only way to tell for sure is to take the heads off ...
you can remove smog equippment to gain a few HP here and there, in fact, i ran my 1.8L D-Jet with nothing else but the MPS and Brain, no Decel-Valve, no AAR ...
works just fine ...
Andy
