QUOTE(rmital @ May 20 2012, 09:53 AM)
QUOTE(914itis @ May 20 2012, 09:50 AM)
I have a broken dizzy wire, can I use a sudering gun to fix it or do I need a special tool?
...was this an existing condition maybe causing your high rpm studdering??
and yes, I've read before someone using a soldering iron/gun to fix the ground wire.
No ray, my situation is getting worst, I went as far as replacing fuel pump, filter again , added the resistor to cht. Wilrod gave me a 2.0 dz with a broken ground, I also borrowed an ecu with harness from him to try to solve the issue.
