QUOTE(pcar916 @ May 21 2012, 06:53 AM)
1st. Do you know for sure that both bulbs are good on the bright circuit?
2nd. Unless you've done it already, go through all of your connections from the fuse box to the lights and clean any corrosion. Without clean connectors you're fighting an assumption.
3. Next look into the relay and make sure it's working.
Not much more to check
Good luck!
1. New bulbs functioning just like the old bulbs
2. Other than the plugs onto the lights, where are these connections? I"ll refer to the shop manual for which fuses to look at.
3. I have yet to find any relays, where should I be looking?
Thanks
