QUOTE(vsg914 @ May 23 2012, 03:46 PM)
Its been a long time since ive been stumped, but this one has me. Ive been helping out cliffordb to get his car straightened out and running right. Its a 76 with stock throttle body. The p.o. had the diz advance hooked up to the vacuum port on the plenum meant for the decel valve. wtf? Removing the hose from diz and plugging results in backfiring, and dieing. It idles fine when attached, but has a bad hesitation at throttle opening. What the heck am I missing here? all components have passed testing. Valves, dwell, and timing have all been verified. No vacuum leaks. Tps adjusted.
Forgive me if you know all this.
I have a 76 and in theory it has a single hose from the throttle to retard on the dizzy. Advance on dizzy is a short tube to air (keeps mice out?
). As I understand it the port for retard is to retard spark at idle and then as the throttle opens the vacuum retard goes away, allowing more advance. The port on the throttle body is just behind the butterfly. The plan was to reduce curb idle NOX emissions by retarding the spark, but that causes poor running as well.
The fact that you need the advance hooked to vacuum tells me that the timing wants that advance - but on a 76 vacuum advance isn't supposed to be there. I think the problem may lie with too much retard at idle. I seem to remember that the instructions for timing in the manual(s) I used were ambiguous. Normally you set base timing with the hoses off the dizzy. I am not certain that is the case with the 914. I think it might work to pull off the advance, plug the vacuum leak, and while leaving the retard hose in place set the timing per instructions at idle and at 3500. That would give you better timing at idle and may solve the problem.
I should have taken notes because I don't have that system anymore - I put on an earlier throttle body and now run both ports hooked up as in the earlier models. My experience was very positive - increased torque and smoother curve.
From what I know with other engines of the era, the vacuum retard wasn't really doing anyone any favors, and can be dispensed with. The CAT saved the automobile. At least here in the US.
