New clutch assembly and new/resurfaced flywheel installed. PO had it done and drove maybe 50 to 100 miles on it.
The flywheel pins are missing. The holes are in the flywheel but the pressure plate is mounted 60 degrees off – see pic.
Red X = correct position of hole in relation to PP position.
Red dot = actual location of hole – under pressure plate.
Everything I read says… if the pressure plate is to be removed and reinstalled then an index mark is made first - so balance is not lost.
So if I remove the pressure plate, add the pins and reinstall the PP using a clutch centering tool, could the assembly end up being unbalanced?
What could happen if I leave as-is and reinstall in my car?
