ottox914
May 25 2012, 06:27 AM
Been a bit since the last time I did a clutch IN a car. I seem to recall hearing of doing one w/out taking the trans out. I'd rather not have to do that, as removing the exhaust, turbo bits, and trans adds a lot more work. Ant thoughts or hints/tips? Its just me in the garage today, so hopefully I can get this done for the weekend.
r_towle
May 25 2012, 06:38 AM
nope, it needs to come out.
rich
URY914
May 25 2012, 06:40 AM
You could leave the trany in but it would be the first time it will have ever been done.
Dr Evil
May 25 2012, 06:41 AM
Wow, it would be the first time I have heard of it and I dont think it can be done.
Dr Evil
Actually, ya you can leave the tranny in, but you will have to remove the engine to get to it
r_towle
May 25 2012, 06:43 AM
I suppose if you have some training in magic it might be done.
The issue is behind the tranny...you will hit the underbody before you pull it back far enough to remove the input shaft from the pressure plate...
If you have enough room behind it, you may be able to pull it all the way back, but you need to get that shaft all the way out of the pressure plate before you can remove the pressure plate....
So, while it might be done...with magic, it is faster to remove the tranny without magic and go from there.
If you still have the underbody heat shield in place over the muffler, that is where you will hit.
If that has been removed at some point, you might be able to do it.
rich
Luke M
May 25 2012, 06:44 AM
Every clutch job that I've done in a 914 I had to remove the trans. Just support the engine w a jack n stands. Once I got the engine low enough I put 1 jack stand under each side of the engine then put a 2x6 across the headers to support the back of the engine. I've removed several trans in my 914 by myself in my younger years. Yes, two people make the job alot easier for sure.
Cap'n Krusty
May 25 2012, 08:08 AM
It CAN be done without removing the tranny from the car. I've seen it done by pulling it back and letting it hang by the axles, laying on the HEs. The guy doing it believed it was faster, but I'm not so sure. Still, under an hour IS pretty good time.
The Cap'n
dakotaewing
May 25 2012, 08:54 AM
Wouldn't it be faster to drop the entire drivetrain and change the clutch once dropped?
rjames
May 25 2012, 10:24 AM
Please don't let anything rest on the heat exchangers. That's a good way to pull an exhaust stud.
Just take the trans out, it's not that difficult. Plus you can get a look at the throwout bearing while your in there. Pelican has a great step by step with pics.
pt_700
May 25 2012, 10:33 AM
although it's been awhile for me too, i agree with several posts above. that tranny has to come out. i was able to allow the engine to tilt slightly down in the back to get enough clearance to separate the tranny.
ottox914
May 25 2012, 03:12 PM
I've had an engine and trans out more times than I care to recall, between my car and the other "friends" I have that "invite" me over to play cars at their place.
I was hoping this would be a quick deal, but, yea, whatever. Between the kerry hunter header and turbo system, I "think" I can get the trans out w/out needing to dismantle the header and turbo bits.
Dr. Evil- check your PM's.
Dr Evil
May 25 2012, 03:44 PM
Dave, reply sent. Lets do this!
ottox914
May 29 2012, 02:47 PM
Just gave in and pulled the trans after taking some of the turbo stuff off. Exhaust stayed on, but just didn't the weight of the trans on the kerry hunter system thats in there. On a stock exhaust you'd have support at both sides from both HE's, but, well, it just looked a little scary. But not as scary as the pressure plate.
What?!?!?!?!
Called the mfg, PP has been sent back to them. Can't have 1500 miles on this. Can't imagine I didn't see this when it was installed. Can't imagine what broke to cause this condition. Soooo slipping clutch due to whacked PP, not contaminated or grenaded clutch disc.
Results and costs following the teardown of the PP will determine the scope of the "while I'm in there" part of the project. Being still sub-optimally employed, (no job) what little $$$ I have hidden away had to go a bit farther than when the black ops fund was receiving bi-weekly assistance...
Anyone with thoughts on this?
And- the clutch disc I pulled out was a factory 6 spring. I had another factory 6 spring NIB that I pulled out to compare to the one that was in service. They were pretty identical, except that the center, splined section was maybe 1/4" longer on the NIB clutch disc. Both are Sachs. Any problem using either disc in the car?
Cupomeat
May 29 2012, 02:55 PM
THat is VERY unusual.
Perhaps one side of the diaphragm has cracked/broken causing the uneven pressure across the wear surface.
I've never seen one like that, but it has to fail somehow.
As for the 1/4" deeper hub on the disk. Not sure it should matter but I don't know which is original length, the current (and the other is 1/4" shorter) or the other way around.
Get a measurement and we could tell you which is stock length.
Eitherway, mostly likely you'd be fine as there is a fair amount of room in there. You just wouldn't want the splines ending and the disk being pushed backward by the input shaft toward the pressure plate.
Interesting failure, thanks for sharing.
Dr Evil
May 29 2012, 03:00 PM
Any of those disks should be fine. The 4 spring disks are even thicker in the center. Strange failure, for sure.
Valy
May 29 2012, 05:27 PM
How is your flywheel?
Looks like the throwout bearing was pressing off center but I can't know who caused what first. Was the bearing properly installed?
Anyway, I would double check the bearing as they are not build to sustain lateral forces and it may have some heay wear now.
ottox914
Jun 4 2012, 08:46 AM
Hows THIS for customer service...
On Jun 4, 2012, at 9:37 AM, brett baltau wrote:
The clutch had a broken diaphragm. Not sure of the cause of it braking. It has been fixed and sent back out to you already at no charge.
Brett
Kennedy Engineered Products
38822 17th st. east
Palmdale, Ca. 93550
brett@kennedyeng.com
Phone 661-272-1147
Fax 661-272-1575
They have earned a customer for life with me...
ape914
Jun 4 2012, 11:57 AM
QUOTE(ottox914 @ May 25 2012, 05:27 AM)
i would be interested in seeing photos of the turbo bits on your car, what you got????
bembry
Jun 4 2012, 04:32 PM
QUOTE(r_towle @ May 25 2012, 05:43 AM)
rich
What is this heat shield you speak of? What does it look like?
ottox914
Jun 4 2012, 05:07 PM
QUOTE(ape914 @ Jun 4 2012, 12:57 PM)
Check out the links in my sig.
