1972 914 main body wiring harness This is a very good condition harness that was removed from a nice 1972 Porsche 914. It appears to be in excellent condition for it’s age. It’s NOT your typical hacked up. NO 12 different radio’s or add on accessories. After extreme care was taken to remove it from the car, I looked it over very good and found only 2 ez repair locations that would need attention, one at the fuse relay board (been cut) and one other single wire (been cut). All original connectors appeared good, even where most removals cut or at minimum damage the harness at the point that it goes thru the rear firewall. The body was cut away to allow such impossible removal. This is a 40 year old harness and not brand new, although I foresee no issues other than mentioned, it could have an unforeseen issue or two simply due to it‘s age. As you probably have found out these harnesses are very hard to come by and when they do they are usually hacked up over the years and NOT in this condition.
$125 shipped priority mail
please add replay with comitment to buy so I can remove item
