VegasRacer
Oct 13 2004, 01:30 PM
The engine lid latch on Elvira was relocated a few inches to the right of the stock location. (the big engine was in the way). The PO modified a stock cable but it is FUBAR. What has anybody else done for engine lid latches other than stock? I am thinking of adding something like hood pins. Ideas? Suggestions?
fiid
Oct 13 2004, 01:32 PM
In the same vein - I would like to see pics of this on tube frame cars where the peice that the latch is located on has been removed.
Aaron Cox
Oct 13 2004, 01:33 PM
cambellcj has hoodpins on his enginelid
brant
Oct 13 2004, 02:44 PM
I did away with the stock latches, hinges, springs and all on my race car....
Oh course I don't have my new digital camera yet...
but soon....
so here is a verbal description of what I did:
I didn't want the weight of 4 hood pins
the rear rubber bump stops make a good point to mount the rear pins, so I needed to come up with something for my fronts....
I welded a very light weight bracket onto my engine lid.
through this bracket I bolted on an aluminum pin pointing to the front of the car (parallel with the ground)
At the top of the engine firewall (just below the window) is a double layered section of firewall. I drilled a hole into this boxed channel on the motor side. I then found the appropriate rubber/hard plastic gromet to fit this hole.l...
So... My engine lid has 2 forward pointing (aluminum) pins that poke into the 2 holes as forward mounts. Then you lower the back section of the lid down onto the (aluminum) hood pins mounted in the bump stop locations.......
This was the lightest solution I could think of.
(I even drilled 4-5 holes into each of the braces that hold the original bump stop mounts)
brant
groot
Oct 13 2004, 02:50 PM
I did something similar to Brant.
But, I used two small lift off hinges that I rivetted to the lid and the body. So, my lid is removable, too.
groot
Oct 13 2004, 03:03 PM
Pic of hinge... avaliable from McMaster Carr.
brant
Oct 13 2004, 03:06 PM
cool idea thanks for the pic..
so lift off or not lift off.... I like that you could just tilt it for an oil check or quick look.
I only made mine lift off, and may regrett it if I bang it up a bunch from all the constant removal.
brant
