If you plan on doing ANY track related events, go with a 05-06 Corvette LS2 pan. These are sought after with better baffles and does not interfere with the shift rod. Having said this the rod interference issue comes into play with the engine mount (Renegades) and needs to be notched in that area - simple but some fab work required to get it right.
Below in the pic you can see the LS2 pan is above the engine mount member (what you want) and the shift rod clearing everything. I don't have a picture of the rod itself.
Shift rod (what we did):
1) Cut rod over engine mount bar.
2) Take 2.5" per side off the bar in length from that center cut.
3) Weld another bar on top of the main shaft on the front piece (Cockpit sit).
4) Index & rotate the back side of the bar (and bend if necessary) to get the necessary movement (tack weld during NON DRIVING TESTING).
5) Once the correct position is found weld in - we basically had a notch with a bar welded on top of both end halves. Worked well and never gave me fits - even in DE events!
