I don't know if this is the same one with a white button, but I noticed it on evil-bay recently as a possible substitute with a white button which you could paint "chrome" into the bezel edge backside. Can't speak to it's fit, quality, etc.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...=true&rt=ncThat link now shows ended, but contact the vendor DSNW who carries them.
Also be sure o use proper wattage bulds per the 914 owners manual, because there were brighter higher wattage dome light bulbs out there which fit in 914s, but were intended for other VWs & other cars whose dome light mounting point could stand more heat.
This is a common problem on interior & exterior lights where folks try to bump the light output/brightness with a higher wattage bulb - or save coin by using an off-brand cheaper correct wattage bulb which may or may not have been made to the factory specs for heat output - and then they end up with a more expensive fix due to a fried lens!
"Back in the day" I had the wrong one in my 914 dome light, which melted/warped the lens & burnt through a bit in the center of my now "unobtanium" original light!
Cheers!
Tom
