shepmon
Oct 14 2004, 11:00 AM
Looking to potentially replace my bosch platinum plugs. Thanks shep
ArtechnikA
Oct 14 2004, 11:05 AM
something like a WR7DS would be my suggestion.
depends on if it's the stock 2,0 or "something else" ...
i like the Bosch Silvertips a lot.
i'm running a finewire Denso Iridium in my 911, the jury is still out on whether those work or not... i think they're okay but i'm seeing more tip erosion from the Crane HI-6 than i think is appropriate, and i think the good ol' Bosch SilverTip is probably (still) the hot setup.
Root_Werks
Oct 14 2004, 11:08 AM
WR7DTC's or W7DTC's
Good heat range for driver use, not hard track. Tripple electrode, good for stock CD ign.
joea9146
Oct 14 2004, 11:12 AM
If u are running carbs I like NGK I think the # is BP7es
jim912928
Oct 14 2004, 11:17 AM
I'm running Bosch 4-tip plugs in my 928 and love them....wondered how they would perform in my 911 and 914....?
Root_Werks
Oct 14 2004, 11:34 AM
If you run carbs, the platinum tips tend to get carb'd up. The standard copper cores work great. Yeah, NGK's rock too.
morgan_harwell
Oct 14 2004, 01:20 PM
When I first did my 914/6 conversion, I put the "latest & greatest" Bosche platinum plugs in the CIS motor. As soon as the mechanics at Garretson's saw them (914/6 was having rough running issues), the platinums where hustled pronto to the nearest land fill. "Use Bosch copper plugs" they advised. They were right, I have never pulled a bad copper plug out of that engine.
campbellcj
Oct 14 2004, 11:26 PM
I've been running NGK's for quite some time and they work well. You want the BP#ES flavor where # is typically from 6-8 depending on your particular application. NGK's go hotter as the #'s increase which is the opposite of Bosch IIRC.
J P Stein
Oct 15 2004, 02:05 AM
Actually, NGKs go colder as the number increases....but that's not important now.
I too am a big NGK fan. Running BP7ES with 9.7:1 compression....seems about right.
Gint
Oct 15 2004, 06:42 AM
Standard NGK's for me also.
Root_Werks
Oct 15 2004, 10:30 AM
"7" in bosch or NGK should be good for a "driver". Had a guy with a 2.8 come in running rough. Said his plugs kept fouling on him. Pulled on, yep, black. Hmm, 5's, little cold for a driver. Popped in some W7DC's and he has been happy ever since.
Bosch 5's would be good if you did nothing but start the car and keep your foot to the floor all day. Like a track car, or on the autoban.
campbellcj
Oct 15 2004, 11:36 PM
QUOTE(J P Stein @ Oct 15 2004, 01:05 AM)
YUP...my bad...martini glass was quicker 'n the keyboard last nite
I'm running BP7ES's right now as well. I have some BP8ES on hand but so far the 7 is on the mark for this engine, even in hot track conditions.
