1. Turn the headlights on, then turn them back off. That puts the headlight motor in the "down" position.
2. Remove the relay that you find under the black plastic cover in the front trunk. This will let you keep your fingers if you accidentally move the motor position.
3. Loosen the jamb nut on the headlight stop, located on the back wall of the headlight bucket next to the motor, and screw the slotted screw all the way in until it matches flush with the jamb nut.
4. Loosen the three screws on the inboard headlight pivot, located in the front trunk.
5. Loosen the 2 screws on the outboard headlight pivot, located under the fender.
6. Move the headlight assembly around until it fits the opening correctly. Hold it there and have a helper tighten all of the pivot bracket bolts.
7. Put the relay back in, and turn the lights on and off a couple of times. Verify that the headlight ends up adjusted correctly when closed.
8. Turn the headlights on.
9. Adjust the headlight stop until it makes contact with the bracket on the bottom of the headlight pivot arm. Make sure it is touching, but not pulling on the bracket. Then tighten the jamb nut.
10. Turn off headlights.
Now go have a beer.
