Doing final assembly of my 914 teener and taking care of odds and ends....
Where is this ground suppost to be located?[u]
?negative battery terminal?
I have an open ground. in the harness i.e. no ground from my harness over my tunnel that supplies the:
Center console gauge cluster and heater blower light sign on the tunnel.
as well as the interior back pad light (which only works in the door switch selection) when it is supplied ground via the door jamb switches:
i.e. per the wiring diagram the same ground for all of the above is disconnected.
per the schematic the ground for all of these is to originate in
"10 / ground connection engine compartment"
see current track 62 from the schematic.
Thanks in advance for the help
