larss
Jun 1 2012, 10:12 PM
I have been running in the new cam on my newely assembled engine on the bench, still have it on the bench, is there a recommendation to re-tighten the heads before putting in the car?
/Lars S
Valy
Jun 1 2012, 10:26 PM
Doesn't heart to tighten them.
The reason for triggering is that after few heat cycles, the heads seat better on the cylinders by smashing the contact surface just a bit.
Same thing happens to the valves so you'll need a new adjustment.
Repeat this after 5-6 heat cycles and few run hours.
larss
Jun 1 2012, 11:33 PM
Thanks Valy,
Yes I found the valves needed adjustment, will re thighten the heads.
/Lars S
TheCabinetmaker
Jun 2 2012, 05:27 AM
To retorque all the head bolts you will need to remove the rockers so a valve adjustement will be necessary.
