Zeke
May 11 2003, 08:33 AM
No, not the guy in the black L&N engineering shirt. That's Steven, who drove Charles Navarro down from Pasadena in his 2002 Boxster S. Nickie rode in the trunK.
Bleyseng
May 11 2003, 08:35 AM
102's?
What are you going to do with them?
Geoff
Zeke
May 11 2003, 08:38 AM
Can you not load 2 pics in one post? Here's a close up of Nickie and his friends the studs, in the bag which unfortunately you can't see. Geoff, I don't know what size exactly, but it wasn't a 96, that's for sure. CN was kind enough to bring Nickie down for a 914 get together. Nickie enjoyed himself. Yes, he was all by himself. BTW, I'm not doing anything with Nickie in the near future.
PatW
May 11 2003, 12:16 PM
Are them those hot set-up cylinders that Jake Raby is offering for Type IV's...
Jeff Krieger
May 11 2003, 12:30 PM
I'm glad to see that there are still companies producing (and improving) parts for our beloved air-cooled motors.
Aaron Cox
May 11 2003, 12:49 PM
are we talking nikasil?
nickie=nikasil?
Mark Henry
May 11 2003, 12:59 PM
Yep, nikasil.
Raby will install them, but LN manufactures and sells them.
With pistons and head studs $3000.
I think I’ll go with bored out 96’s
bernbomb914
May 11 2003, 04:51 PM
Those nickkies are 106's Charles said they will run cool and long, will work as well as 96's. They are also developing a new head to match with better flow and cooling. he said the market is big in midgets. should make big HP for a four about $3000 for each. get a good cam good crank clean up the case and bolt together.
bernbomb914
May 11 2003, 04:53 PM
more
bernbomb914
May 11 2003, 04:55 PM
more
bernbomb914
May 11 2003, 04:56 PM
and
bernbomb914
May 11 2003, 04:58 PM
that was zeke's race car
Jeff Krieger
May 11 2003, 04:59 PM
QUOTE(bernbomb914 @ May 11 2003, 03:51 PM)
... They are also developing a new head to match with better flow and cooling.
I vote for heads with OHCs.
bernbomb914
May 11 2003, 05:01 PM
and
bernbomb914
May 11 2003, 05:02 PM
last
Aaron Cox
May 15 2003, 05:43 PM
QUOTE(Jeff Krieger @ May 11 2003, 02:59 PM)
hey, while we are at the wishing well, i want four valves a cylinder, DOHC, etc etc.
how would one go about doing an OHC head for a pushrod engine? external belt/chain?
Mueller
May 15 2003, 06:01 PM
LN is making brand new heads, supposedly, they are going to be good for 200-300hp out the box....cash in your 401k for a set
I look forward to seeing what kind of reliable power can be extracted from these Type IV based motors
Whos green 914 is that?
VERY NICE 914
The easiest way to drive the cams in a OHC motor is belts (dry) less work and expense.
Aaron Cox
May 15 2003, 06:24 PM
but if the belt(s) failed, would the engine have an interferance problem....such as valves smacking pistons and so forth.?
i know it is purely speculation as to a ohc head....take an educated guess
Mueller
May 15 2003, 06:31 PM
Depends on the design of the motor .....not all engines are "interferance" motors.
piston design, valve lift, combustion chamber all makes a difference....
My old Volvo 745 had a belt let go...no problems...if the belt lets go in my newer Volvo, big repair bill would be in store.
Aaron Cox
May 15 2003, 06:34 PM
i too have two volvos!
a 240
a 940 turbo
*both non interferance motors
