QUOTE(Cevan @ Jun 4 2012, 07:34 AM)
Or you can simply plug the fog light relay into a different fuse under the dash. Actually it takes movement of both the relay hot wire and the switch hot wire if I remember it right.
You don't need to buy something - although I am not knocking the product, and the wiring change is a simple matter of changing where spade connectors go. It took me less than half an hour.
The basic idea is to wire the fog lights from the head light fuse. Notice that the headlights go off when you turn off the key, but the running/parking lights don't? You want the fogs to do the same.
Then you just pull out the fog light switch and leave it there. Lights on when the car is on, off when off.
