QUOTE(Ductech @ Jun 6 2012, 04:08 PM)
And here I thought keeping my 901 behind my Subaru motor was nuts... It would be spendy I imagine... And after you get to the point of stacking up a motor to it with the added thickness of an adapter the trans would stick out quite a bit. From what I've seen most Subaru motor/ trans conversions are long in length and encroach on the space the stock exhaust would sit. Also the diff itself sits low in these trannies, so u may loose some ground clearance albeit in line with the wheels. My 2 cents... If it matters. Don't let my ramblings discourage you.
Using a Subaru engine/transmission in two wheeled drive keeps the assembly at about the same or less length than a T4/901. The T4 motor is a bit longer than the Subaru, so add in an adapter plate and that combination might be a bit longer by an inch. The transmission input height is a bit higher for the Subaru transmission, so it could change the engine position. When it's combined with the Subaru engine as a unit the engine cradle or other mounts it positions the drivetrain correctly, but I don't know about the T4 or 911/Subaru tranny combination. I haven't seen any lack of ground clearance to the transmission and my car's very low, you'd slide on the belly of the car long before the transmission would contact. I can see a Subaru/901 conversion as logical because I don't have any enthusiasm for T4 engines. And a Subaru engine/Subaru transmission is magic. Then a T4/Subaru transmission is a possibility, but for me it's not compelling because after you've done a lot of work you're still stuck with the T4. I can't see that as being worthwhile, but it's a question of personal taste.
There's something else. I don't know how to quantify it, but the 901 isn't modern technology. Engines have evolved a lot in the last 45 years, and transmissions have evolved as much or more. They're more efficient because they have a large affect on mileage, so automakers prioritized improving them. But being more efficient is more than just gas mileage. When there's less power loss in the drivetrain it means more horsepower gets to the wheels, and more power from the same engine is a Very Good Thing. But to the point of the thing, I wish you could drive my car, it's been transformed. It's a pleasure to shift, in fact I don't even think about it. Not many other 914's can say that.
