Since we are on this subject, there is a much greater threat to all of us. Every home that has a central AC installed, has a copper line set that connects the indoor evaporator coil to the outside condenser unit. This line set has 2 copper pipes, usually 3/8" and 3/4" in diameter. Many installers all over the country uses soft solder (lead) to sweat these connections. This is against code for many reasons, but primarily lead has a low melting point (around 350F). These connections should be brazed with silver brazing alloy, which has a much higher melting point. However, the costs involved with brazing usually deters the fly by night company's from using this technique.
There was a home fire, a couple years back, that started in the mechanical room. The family was sound asleep and was unaware that the furnace had a delayed ingition, which started a small fire. The heat of the flame melted the lead and unsweated the joint on the line set. This in turn caused the pipe to pop out of its joint, this is due to the refrigerant always being under pressure, typically around 100psi on a off cycle. As this connection failed, due to the presense of the flame, 8 pounds of refrigerant (R-22) leached out in a furry in this mechanical room. The burst of refrigerant did happen to extinguish all the flames, and the fire went out. However, the R-22 wasn't R-22 anymore, it was converted to a phosgene gas. Later the next day, the police found everyone dead laying in their beds from this mustard gas (phosgene) poisoning.
7 out of 10 houses I service has soft solder joints. This was not a isolated case, as this happens all of the time. Typically, you would find 4 joints in a typical AC installation job. 2 joints inside, and 2 joints outside. You can easily spot soft solder joints, by looking at the shiny metallic joint. Brazing, usually leaves a much darker, harder look to the joint.
Soft solder is meant to be used when sweating copper water plumbing pipes together, not refrigerant lines. Water pipes run around 60 psi, and lead has no problem sealing against this pressure. Refrigerant lines can get as high as 350psi, and the soft solder over time, can't hold this. You start to see oil residue leaching thru the joint. This is another reason to why it is not code to soft solder refrigerant lines. I would recommend spending 5 minutes of your time, and check to see if your have soft soldered joints. If you do find them, get it fixed now. Your just playing Russian roulette otherwise. Plus, after you fix these joints, you can experience an AC unit that doesn't leak anymore! R-22 is starting to get expensive.
Click to view attachmentleft pic is soft soldered
right pic is brazed
