QUOTE(Elliot Cannon @ Jun 4 2012, 03:54 PM)
QUOTE(Cap'n Krusty @ Jun 4 2012, 04:41 PM)
Now that the hard ways have been proposed, take a look at the way I do it, which can (surprisingly conveniently) in the classic threads forum. Invest is a remote starter button, or a piece of wire with with a female push on connector on one end and the other having an inch or so of exposed wire. Put the car in neutral for this process. "Bump" the engine over until you have one valve rocked all the way open. Adjust the valve opposite the open one. Repeat as necessary. Once you become familiar with the procedure, you'll notice that TWO valves (but never on the same cylinder) are always open at the same time, simplifying the job. No jumping up and down, no need to find TDC, no fooling around with chocks, tires, broom sticks, or anything else, just a relaxing 5-15 minutes under the car.
Good luck!
The Cap'n
The Cap'n is right again of course. Although I have to take issue with the "just a relaxing 5-15 minutes under the car".
Of course, he has been working on these cars for 65 years now and.....
may i offer another option ? or a modified one ?
remove the spark plugs ( for ease of rotating crank ), select any gear, lift the rear wheels off ground, use any method you like to stop the opposite wheel from rotating, as you rotate the free wheel watch the rockers of any cylinder, when those two rockers are rocking in opposite directions ( valve overlap ) adjust the valves on the cylinder directly across the engine.
This method is supported by a Porsche factory tool for applying the e brake to one caliper or the other. Tool US8001 wheel lock. This is a 914 specific tool.
