QUOTE(McMark @ Jun 6 2012, 12:46 PM)
Good thing you plugged it. You almost let all the air escape from the engine.
It's not for the compressor bracket. At least not in a 914. The four holes on the side of the fan housing are for the compressor. The 912E had the compressor moved up to the top of the engine because it wouldn't fit in the 'old' location in that configuration. But the hole in question pre-dates the 914E, so it wasn't put there with the AC in mind.
Remember that this engine was developed with the VW 411/412 in mind. So there may be something on those cars that uses that hole. It's my understanding that the Type 4 engine was applied to the 914 a little later in the development of the engine.
The four holes on the side are for the compressor? But,but, the factory never intended for an ac to be installed in a 914.
