The horn isn't working on my LE. The wire is there & connected but I get nothing. It's definately connected to the horns also? What would you suggest to check next?
I also have a leak from the rear main seal. I'm going to pull the drivetrain saturday to replace it. I'll replace the flywheel O-ring along with the Flywheel pilot bearing/felt washer & the flywheel crush washer. The rear main seal is the main thing. Any tips or tricks on getting it to seal properly?
On my high beams they will come on if you hold the lever back. They will not click to stay on though?
As always thanks for the help
