service your 914 with a specialist, and you will see the differance
examples of prices..
clutch installation $799.00
includes all new oem parts
sachs clutch 4 or 6 spring disk,new preasure plate, new t.o bearing, turn flywheel,
new main shaft seals,new o ring on flywheel, new c/v joint gaskets
rear trunk lock broke?
$199.00 to unlock and fix broken contact tab. no drilling, no cutting
top end rebuilds starting at $990.00
complete case split rebuild starting at $2600.00
transmission rebuilds starting at $979.00
ratio changes and limited slip diffs conversions avail.
complete tune up with all new bosch parts $375.00
f.i. tune up and ox2 set starting at $99.99
all new fuel line german braided h.p. hose $269.99 (2.0, 1.7) $289.99 1.8 l-jet
injector seals replaced $129.99 new connector hoses at plenum included
fuel tank rebuilds $199.99
pushrod tube seals replaced $229.99
oil cooler seals replaced in car $269.99
engine, trans, body, electrical, stock or custom.......we do it!
951-907-0362
premisis gaurded by cctv and alarm
aluminum fabrication and welding////fiberglass fabrication
rotiserie builds, complete gt conversions
- it's NOT ok to contact this poster with services or other commercial interests
View the full article
THIS IS NOT A 914WORLD AD!
Do not reply to this thread! No one is listening!
Click on the "View the full article" link above to go to the actual Ad!
