I was going to make one for you, but I forgot.
I cant get one for you until next week as I am working 12hr+ shifts every night this weekend (I am at the hospital now
I can do one in prose, though.
1) Remove the bottom rear cover.
2) See the little dong thing on the shift rod in the space you just exposed.
3) Move the shifter in a position to allow you to drive the roll pin out that holds the dong.
4) Slide the shift rod out.
5) Pull the seal and replace.
6) Assembly is the reverse.
It is not too hard
