This is a BOGE strut with 3.5" caliper bolt spacing. The struts and backing plates and top hats are powder coated gloss black.
The hubs were sand blasted, wire wheeled and clear powder coated. Included are the caps, spindle nuts and keyed washers. No inserts are included but I might have a decent set of BOGE inserts to through in for free. Used bearing are included. You will need new rear seals.
Not pictured but included are used core A calipers. They may work as it. I can also include a pair of used rotors if the buyer thinks the shipping is worth it.
I can send them in a flat rate box with the calipers for $15.
I also have the 911 A arms with torsion bars, and under body sway bar for $100. Original finish on the A arms. Bars have been powder coated. Buyer pays shipping from 92505 CA. Figure $50-75 shipping cost. Local pickup preferred in Riverside CA.
Bruce
