QUOTE(pbob42 @ Jun 11 2012, 11:00 AM)
No fuel to my '73 914 2.0. I Measure voltage at the pump and I get a 12v hit for about 1 sec when the key is turned and then it dissappears. Voltage is constant at pin 87 on my fuel relay.
Any thoughts?
Is it still fuel injection? If so, the FI brain will only run the fuel pump for about 3 seconds or so to build pressure.
You can always try to switch relays, they are all the same, including the ones used for the headlight motors.
Also make sure the relay fits snug in the socket. If not, you can carefully pry the prongs apart to give them a better fit.
If your relay socket is dirty, clean it first.
Disconnect the battery before cleaning! PS:
