Some Spec's STI Block 2.5 Darton Sleeves, O ringed heads, ARP head studs, JE Pistons, H beam race Rods, Turbonetics E50 Ball bearing Turbo T3/T44, Tial wastegate, cermaic coated exhaust polished BOV, Billet fuel rails, 83lb Bosch Injectors, upgraded Cams with all upgraded retaining parts, aluminum pulleys, carbon front cover, new pulleys, new belts, chromed heads, billet filler neck, polished intake, polished water cross over, polished alternator, custom oil pan, custom breather system, flywheel and clutch, all steel braided lines included.
I've seen these motors in Volkswagens and Porsche 914's
What you would need is a bottom end rebuild or a short block, computer and intercooler
This is the shop that the motor is at and all the parts listed above is on the web site.
http://www.outfrontmotorsports.com/400hp_setup.htm
Video of running motor
http://s260.photobucket.com/albums/ii26/ragekills/?action=view¤t=SU.mp4
- it's NOT ok to contact this poster with services or other commercial interests
View the full article
THIS IS NOT A 914WORLD AD!
Do not reply to this thread! No one is listening!
Click on the "View the full article" link above to go to the actual Ad!
