I've been wanting to have a set of custom made brass oil lines for my 914/6 since I first got it back on the road about 3 years ago. I've not been comfortable using hose to carry the engine oil up to the front cooler and back. It works, but I'd like the brass due to it acting as a heat sink, and since it's rigid it'll never deteriorate like the hose would.
So, about 3 years ago I bought some 1''brass tubing from McMaster, and a cheap tubing bender from Harbor Freight and tried to bend up something that might work. Well, to say the least, there were a lot of wrinkles, and I couldn't make a 90 w/o crushing he tube. So the best I could manage was a set that physically fit the chassis, but would never be functional.
I then commence to spend the better part of 3 years Google searching and calling every tube fabricator I could find, but no one would take a chance. No volume. a one time job, no one wanted.
Then I saw Eric's thread about repo'ing he GT style Hard lines. We talked a little about my application, since it's different due to the 3.6 engine, and I went back on the hunt for a tube former.
Well, I think I finally found him. My bottom line is basically straight with a 90 degree bend where it enters the chassis, and a slight drop back near the thermostat. Well, I asked the fella if he'd form me a L-shape, a 1' leg, formed 90 degrees, followed by a 5' leg made out of 1'' OD x .030 wall annealed Brass. He came through, and now on Monday Ill take the line down to have the ends flared for final fitment.
After that, I'm going to box up my upper test line and send it to them to copy.
So far, So good. Maybe in a month, both lines will be Brass....
Cheers All,
Ron
