If the '74 2.0 I have listed doesn't sell, i'm thinking of putting the engine/transmission in the '76 I have. The '76 currently has the original 2.0 with a single carb stuck on it.
I assume the '76 has a low pressure fuel pump in there now. Other than changing over the fuel pump to a factory high pressure one, what else will I need to do? Smog isn't an issue here in SC so I don't have any issues with emissions equipment.
I will change the tunnel fuel lines to stainless and replace all the engine hoses, injector seals, etc. Are the relay boards compatible? What else would I need to change?
Any input is appreciated.
The car I propose to put the engine into....
