QUOTE(Dave_Darling @ Jun 19 2012, 04:50 PM)
If you take a look at the stock 914 (70-74) exhaust, you'll see that it has pipes that go from the exhaust port all the way back to the muffler. The pipes are completely independent, at least until they dump into the muffler. We would hope that the muffler has some reasonably intelligent way to combine the exhaust flows, but it may very well not.
A collector like a Bursch muffler does, in fact, join the pipes together in pairs and then all four. In theory, it can be better than the stock system. In practice, it seems like it's about the same.
There are two distinct ways to go about building an effective exhaust system.
They are named Independence and Interference.
The flat 4 engine with left-left-right-right firing order makes it real difficult to design a system which fits the car, helps the engine make power, and isn't too costly.
The firing order of a -6 makes two separate 3 cylinder Interference headers work perfectly.
The early -4 setup relies on Independence, ie. all 4 pipes dump individually into a large chamber which has the sound absorbing material.
The sound waves in one pipe are only reflected back in that pipe and therefore don't influence the scavenging of another cylinder.
Where the stock system loses effectiveness is the very long pipes, and the convoluted exit path through the muffler.
The Tangerine IV Silencer deals with those shortcomings to improve output while retaining the early heat exchangers.
The individual pipes are kept as short as can be, and enter the muffler independently.
The muffler has the flow characteristics of a straight thru muffler but has good sound reduction due to my unique design which separate sound waves from the gas flow.
All the other aftermarket "header/mufflers" which go on early HEs change the system from Independence to Interference, but don't apply the principles that make Interference work well.
The primary pipes are usually much longer than the original. One (Triad) has shorter primaries but doesn't pair the collection sequence properly.
Even if these designs create equal length pipes they won't produce much gain except for what comes from having a more free-flowing muffler.
A good Interference system relies on reflected sound (pressure) waves travelling from one primary into another.
The goal is to have pressure in the pipes go below atmospheric at a particular time in the combustion cycle to improve scavenging.
The pipes need to be joined in a particular sequence with a specific length, determined by the engine's firing order, rpm powerband, and to a limited extent, cam timing.
The ideal length is much shorter than stock HE's so anything added onto them will not be an improvement.
HE pipes are in the range of 50 inches.
European Racing Header primaries are 40" long - good for low end torque but not great for peak power.
A Kerry Hunter Header has 34" primaries IIRC.
Tangerine EVO Street primaries are only 30", Race primaries are 26".
The Tri-Y (4-2-1) layout of the Tangerine header takes the Interference design to the limit and creates midrange gains not available from a 4-1 header, while still making great peak power by having a tuned short overall length paired with the most free-flowing quiet muffler.
