tornik550
Jun 18 2012, 07:56 PM
My alternator hasn't been working for a long time. I have rebuilding my engine so I never needed one. I replaced it tonight with a new Bosch 55a (what a pain). I hooked everything up and now when I go to hook up the battery- the wire arcs across to the battery post when I try to hook it up- wtf!!! I am an electrical idiot (along with other things). Anything is possible. I have made no other changes other than the new alternator. Inside the alternator, I did have to hook up the harness wires. I hooked up three things on the inside of the alternator- the big red wire to the area pictured, the wire from the black box on the alternator to the area arrowed and the obvious three pronged plug. There was a rubber boot around the red plug that was brittle and I suppose may not be insulating the ring connector well however I dont see how that would be a big deal.
Lennies914
Jun 18 2012, 08:04 PM
How did you determine that your original alt. was bad? I would unplug the three prong harness and/or remove the voltage regulator off the relay board and see if it still arcs.
infraredcalvin
Jun 18 2012, 08:06 PM
I don't recall what my 914 alt looks like, but I just pulled the alt out of my 930 yesterday, there was a big ground strap in addition to the 3 wires I pulled. Are you missing a ground?
tornik550
Jun 18 2012, 08:09 PM
Well- it turns out that I am not just an electrical idiot- I must be just a general idiot. I forgot to hook up the three prong plug on the relay board. Damn it.
My goal is to someday post something that is half way intelligent. Maybe someday.
Dr Evil
Jun 18 2012, 08:23 PM
With a title like "Ignore this post" I have to look.
markb
Jun 18 2012, 08:28 PM
shuie
Jun 18 2012, 08:33 PM
This post?
Mark Henry
Jun 19 2012, 08:02 AM
This problem is caused by a RTMS failure.
Chris H.
Jun 19 2012, 08:17 AM
Can't..............ignore...............
