chris914
Oct 18 2004, 05:54 PM
In converting from tail to side shifter I have made it all the way up to the shift rods.
I can't get the shift rod bushing into the body of the car. It is much thicker then the stock one. The engine is in the car currently.
jim912928
Oct 18 2004, 06:01 PM
Do you mean the bushing at the firewall? I just did this and it took an entire 30 seconds (to push it in)!
1st...I'll assume you have the shift rod from the gear shift lever to the firewall pushed into the tunnel so you are not trying to squeeze the bushing on with the shift rod through the hole
2nd...boil the bushing briefly...softens it up some
3rd...go push it in with your fingers!
With it hard and cold...a bear to get in!
Jim
Oct 18 2004, 06:24 PM
and you have the "conversion" bushing, correct?
Andy
chris914
Oct 18 2004, 06:27 PM
Yes. The stock one is easy to get in and out.
Type 4
Oct 18 2004, 06:36 PM
Try putting it in Boiling water for a couple of minutes.
Take some liquide dish soap and put it on the hole in the body then put the bushing in the body and push it in while its hot.it should slip right in.
chris914
Oct 18 2004, 06:41 PM
I just tried boiling it for 2 minutes then 5. It just laughed at me. I tried pushing it in straight and at an angle.
Hmmm, do I really need it, LOL.
chris914
Oct 18 2004, 06:43 PM
I'll try the soap and the boiling. Be right back, LOL.
chris914
Oct 18 2004, 06:50 PM
Closer. But I just can't get it to pop in. Hmmm.
bondo
Oct 18 2004, 06:55 PM
The side shift and tail shift bushings are different.. BUT, you can't just swap over the side shift firewall bushing because the firewall is different. There is a special bushing made specifically for installing a side shift trans in a tail shift car. That is what Andy was talking about.. make darn sure you have the right bushing or you'll have to boil the whole car to get it in
chris914
Oct 18 2004, 07:03 PM
Thats the problem. The stock bushing is easy. The conversion bushing is a @#$%.
chris914
Oct 18 2004, 08:08 PM
Success!!!!!
I made a tool to pull the bushing into the car from the inside.
The tool is pretty simple but there are a couple of tricks if anyone is interested.
Thanks for all the input and help.
The pictures were taken after I got the bushing in of course.
jim912928
Oct 18 2004, 08:34 PM
amen..success with ingenuity!.....good job!
jr91472
Oct 18 2004, 11:17 PM
way to go
shifting like it was meant to be is within sight
enjoy
