I am beating myself up on how to take care of this rust on the rear lower firewall.
All these penetrations for the clutch cable, accelerator cable, fuel lines, wiring harness, etc are going to make this repair into insanity! BTW what is the medium sized hole and short tube for next to the wire harness?
Center section is the most solid but I feel it must go.
Drivers side section has had the cancer removed, floor pan is still there and will come out.
Passenger side needs to be removed bottom edge was removed by mother nature. I have cut the bad stuff out of the floor pan and inner lower fire wall.
HERE IS THE BIG QUESTION: Should I bite the bullet and start removing the WHOLE section? Or trim and cut and piece the crap out, then piece and weld fresh?
Just looking for a driver here, nothing fancy.
Thanks
