This car is blue with white interior.
This car used to start and run but has been sitting for a few years now and needs a new battery
The car needs a clutch, this would make a great project for a Porsche fan or a great parts car.
The car does have new hankook v700 r comp tires on it. 225 front 245 rear 1200 USD.
The car comes with the forged 16" Porsche Light Weight Wheels ( a very expensive Option when this car was new)
,br> The drivers door handle will need to be replaced.
Call/text for pictures and to see the car.
909-229-7701
Matt.
Keywords: honda parts, jdm parts, gsr head, vtec head, ls vtec, b20 vtec, ls vtec kit, turbo k parts, jdm fog lights, eg parts, da parts, h22 parts, k series parts, jdm racing seats, type r seats, ef fog lights, hellaflush, hellaflush rims, steelies, 4 lug rims, deepdish rims, hellaflush wheels, deepdish wheels, xxr rims, sportmax rims, dr20's, drag rims, j mags, enkie's, volk rims, konig rims, takata belts, 4 point harness, b18 parts, b16 parts, d16 parts, obd0 dizzy, obd0 distributor, obd1 dizzy, obd1 distributor, jdm struts, ef roll cage, honda roll cage, jdm swap, eg roll cage, hatch roll cage, zex nitrous kit, turbonetics, godspeed, k20 parts, k24 parts, hid kit, jdm conversion, jdm hid kit, nrg seats, nrg steering wheel, nrg harnesses, nrg belts, nrg parts, jdm lug nuts, jdm stabalizer bar, gsr head, ls head, b18 head, b16 head, vtec head, d series head, b series head, dohc head, sohc head, dual cam head, single cam head, non vtec head, b20 head, b20 parts, jdm engine, jdm motor swap, ecu chipped, jdm ecu, jdm ecu chipped, hondata, jdm tune, ls vtec, b20 vtec, gsr vtec, vtec solenoid, vtec parts, honda vtec, jdm wire tuck, honda wire tuck, valve cover, honda valve cover, jdm valve cover, vtec valve cover, dohc valve cover, sohc valve cover, golden eagle parts, jdm front end conversion, lsv, b20v, honda distributor, dmh cutout, e cutout, turbo downpipe, e cutout downpipe, dmh downpipe, turbo down pipe, b series downpipe, b series down pipe, b series turbo downpipe, turbo flex pipe, turbo sandwhich plate, golden eagle parts, blackworks parts, b series turbo kit, ef roll cage, eg roll cage, honda roll cage, jdm roll cage, coupe roll cage, integra roll cage, civic roll cage, roll cage, built vtec head, ls vtec tapped head, oil pan, tapped oil pan, dsm injectors, rc injectors, turbo injectors, obd1 injectors, obd2 injectors, obd0 injectors, obd0 jumper harness, obd1 jumper, obd2 jumper, obd0 jumper, p 28 chipped ecu, chipped ecu, hondata, built vtec head, built b16 head, built gsr head, built dohc head, ls head, d16 head, gsr head, complete honda head, vtec head, dohc head, sohc head, ecu on base chrome, jdm swap right hand drive, rhd honda, rhd civic, rhd integra, rhd ef, rhd.
- it's NOT ok to contact this poster with services or other commercial interests
View the full article
THIS IS NOT A 914WORLD AD!
Do not reply to this thread! No one is listening!
Click on the "View the full article" link above to go to the actual Ad!
