solex
Jun 22 2012, 08:02 AM
I have a 75 2.0L with DJET, Euro Pistions, new harness, new CHT, <15K miles on complete rebuild. Before the car is fully warmed up it runs great, but after it is warm the car stumbles over 3500 RPM. I do not have a rev-limiter. Any ideas where I should start debugging this problem would be appreciated.
Regards,
Dan
warrenoliver
Jun 22 2012, 08:26 AM
TPS maybe? Open it and clean and adjust.
Warren
JeffBowlsby
Jun 22 2012, 08:32 AM
Lube the advance weights lately? 1 drop of 30 wt oil on the felt at the center of the dizzy shaft per year is recommended by the factory manual.
solex
Jun 22 2012, 08:37 AM
TPS is new.
I rebuild the dizzy about 3 years ago, will put some oil and report back.
Thanks,
Dan
TheCabinetmaker
Jun 22 2012, 09:51 AM
Could be one or more of several things. Mps could be not holding vacuum, tps could be mis adjusted ( disconnect to test), condensor break down will give those exact symptoms. Checked your dwell lately?
John
Jun 22 2012, 05:18 PM
replace the coil.
