blitZ
Jun 22 2012, 04:26 PM
My brake lights have quit working. Checked fuse, switch, bulbs. All other lights work fine. The lead running to the switch should be hot. Is that correct? Anything else to check?
yeahmag
Jun 22 2012, 04:46 PM
I seem to remember this is a momentary switch (not to ground) and has two connectors. Did you connect the two wires together to rule out the switch itself?
