Full Version: Window adjustment
partwerks
The top of the window and follow it back to the rear corner of the glass
Is there an adjustment to getting that corner of the glass to tip in a bit so that it seals better where the horizontal targa top seal and the vertical roll bar seal meet?
obscurity
QUOTE(partwerks @ Jun 23 2012, 11:21 PM) *
Perhaps someone else will chime in but if I recall there is a nut on the bottom of the door that will make this adjustment
John
reharvey
The glass is adjustable in every direction you can think of. You'll need to remove the door pad to go at it.
