I'm making these to go with our new repair kits, but they are available separately.
Special price valid thru 7/31.
The hollow hex tool is double ended because I've found adjustment screws with significantly different tool fitment. The tool which fits the smaller screw just spins inside the larger screw. The size difference is quite small, but significant nonetheless.
I've decided to make the full load stop screw with a thru-hole so the unit can be properly adjusted without removing the stop screw. A vinyl cap is included to protect the screw after making adjustments.
