Full Version: To Spot Weld or not to Spot Weld
jrrhdmust
So I finally have the right side of the car repaired with panels welded in.
I ordered a new panel from restoration design that meets up with the engine, as well as a new battery tray. It looks like from the factory those are spot welded.
Is everyone spot welding them, or completely welding?
Thanks
URY914
Spot weld it and move on.
VaccaRabite
Zach
ThePaintedMan
agree.gif Don't waste too much time on it. Plus it will make it easier to remove if you need to. I only tacked mine in with 4-5 and it holds fine.
jrrhdmust
