DrifterJay
Oct 19 2004, 08:03 PM
any ideas? tube wont go far enough into the head to seat...
cametal
Oct 19 2004, 08:12 PM
Have you tried lube? Try twisting the tube while pushing with somthing that is close in size to the OD of the tube.
Aaron Cox
Oct 19 2004, 08:15 PM
do you have the right gaskets/seals/orings?
hope it sorts out jay
DrifterJay
Oct 19 2004, 08:19 PM
im not that retarded
Aaron Cox
Oct 19 2004, 08:20 PM
QUOTE(DrifterJay @ Oct 19 2004, 07:19 PM)
wasnt an insult. i thought there were 2 differentones...i may be retarded
Deano
Oct 19 2004, 08:39 PM
I put a deep well socket that was a approx. the same diameter against it and gently tapped it with a rubber mallet while twisting the tube. Watch closely to make sure you are not pinching the o-ring. Hope this works for you.
Mueller
Oct 19 2004, 09:23 PM
...yep, Deano's method is what I use as well....
DrifterJay
Oct 19 2004, 10:51 PM
well it worked....one side was easy...the other side for some odd reason was a lot tighter...had to use some primitive force...but its in....
I might be at the autox...but my car wont be legal....May tags and no current proof...but its only 20 minutes from my house....better than Toasts proposition of using somebodies Ghia plates...hehe...well see....
skline
Oct 19 2004, 11:19 PM
It's just a fix it ticket up to 6 months, then its up to the officer, but he could impound it after 6 months out.
Aaron Cox
Oct 19 2004, 11:51 PM
do it jay!
you gotta man.... it will make working in the army more bareable, youll have happy thoughts in your head
seanery
Oct 20 2004, 08:19 AM
When I lived in Redondo Beach, one of my neighbors had a car that was 2 years expired, no insurance, high or drunk everyday and he drove all the time
