QUOTE(Krieger @ Jun 28 2012, 10:22 PM)
I need the two metal ends that plug into the back up light switch on the trans and the rubber boot that covers them. I don't want an entire harness.
If you can't find the male plugs you can use "blue" butt splice connectors. Strip the plastic off, crimp one end on the wire, slightly enlarge the open end with a small nail or ice pick then slide it in the back up switch.
