hars914
Oct 20 2004, 05:32 AM
I am finishing up my six conversion. I have a 2.0E motor that I am installing.
The alternator has an internal regulator so I have 3 wires to connect.
b+ to battery, D- to ground and D+ which is for the gauge light. When I plug them
into the regulator board do I use the plug where the wiresfrom the alternator connected or where the regulator plugged in or does it matter?
iamchappy
Oct 20 2004, 07:04 AM
I have mine plugged into the normal alternator plug in and have the relay boards voltage regulator removed, it all seems to work fine that way. You would have to put some spades into the voltage regulator plug in area in order to do it that way but I never tried it.
Root_Werks
Oct 20 2004, 08:33 AM
Check here:
http://www.914world.com/bbs2/index.php?act...=2&t=15282&st=0There is the detials of the alt wiring and the backwards part of it.
