QUOTE(bcheney @ Oct 2 2012, 07:20 AM)
Anyone know if this is a 34 or 34R Optima? It was new years ago and has just sat in a dry garage for over 4 years. Hoping it could be charged at a Optima dealer and brought back to life..
Just found this thread on Pelican...great stuff!
http://forums.pelicanparts.com/porsche-911...ma-battery.htmlHow to recharge a deeply-discharged (below 10.5 volts) Optima battery.
Virtually any standard automotive battery charger on the market will charge an Optima battery just fine. However, most automotive battery chargers will not charge any battery that has been discharged below 10.5 volts. If a standard flooded battery is discharged below 10.5 volts, there’s not much of a chance that it will be serviceable again. However, AGM-style batteries, like Optimas, can be recovered from a deeply-discharged state, by using an AGM-specific charger or by parallel charging.
To charge a deeply-discharged Optima with a regular charger, you can wire a second fully-charged automotive battery (12V+) to the discharged Optima in parallel (+ to + and – to –). Then hook up the charger to either battery, setting the charger at 10 amps for 2 hours and monitoring it frequently.
When the discharged Optima reaches 10.5 volts or more, remove the second battery and continue charging the Optima until fully charged.
Typically we recommend charging at a relatively low current, such as 2 amps, but when a battery has been deeply discharged, some sulfation of the battery plates may have occurred. However, if you charge at 10 amps, the higher current will help to break up sulfation that may have occurred. If you have an automatic charger, let it run until the charger indicates charging is complete. If you have a manual charger, estimate charging time by multiplying the capacity (amp hours or Ah) of the battery by 1.2 for a rough estimate of charging time in hours.
In most cases, these steps will recover an Optima battery. It’s ok for the Optima battery to get slightly warm during the charging process, but hot to the touch or hissing from the battery indicates a short and the process should be discontinued. If you are able to fully charge the battery, but it gradually loses it's charge (without any loads on it) over 12-24 hours, the battery is probably not recoverable.
If you’d rather not deal with this process, you can always take your battery to a professional battery specialist, like Interstate, who knows AGM technology. Most of them are willing to provide “charge and check” procedures for a small fee and many will provide the service for free.
If you have any other questions, I’ll do my best to answer them. I appreciate your interest in Optima batteries!
Jim McIlvaine
eCare Manager, OPTIMA Batteries, Inc.
