Gint
May 12 2003, 07:57 PM
Looks like I'm going to have to remove the tank to remove the sail panel and targa trim. It isn't painfully obvious how it's mounted. Any body know the details? And while we're at it, any gotchas when removing it?
Brad Roberts
May 12 2003, 07:58 PM
The lower oil line fitting holds the bottom.
The two 13mm nuts bolt it to the inside panel.
Remove the relay board if you havent.
B
Lawrence
May 12 2003, 08:00 PM
Yeah, unbolting it is easy. Consider replacing the grommets and oil filler gasket while you're in there.
R&R requires a contortionist.
-Rusty
Gint
May 12 2003, 08:03 PM
What's new?
Thanks guys
ArtechnikA
May 12 2003, 08:22 PM
...and be glad your car is squished on the right side, not the left like mine - i'm gonna hafta do bodywork so i can get the oil tank out so i can begin the bodywork ...
Gint
May 12 2003, 08:51 PM
Good point. Although I had to be very creative getting the wheel off the right side!
mr914
May 13 2003, 11:12 AM
I just pulled mine out last week. Sounds like Ginter and I are doing a similar rustoration.
A side note. You do have to take the oil filter spout off to get the tank out.
Mine had a bunch of undercoating and dirt that made it a little difficult to get out.
Discovered something. It appears that the oil tank was originally copper plated and then painted. Is this correct?
Gint
May 13 2003, 11:18 AM
Mine has some missing paint and shows copper or brass below. It's still in the car at this point. I have heard in the past that they are copper (I think). Someone will correct me if I'm wrong.
JWest
May 13 2003, 12:06 PM
The oil tank is steel, copper plated, then painted.
Gint
May 13 2003, 01:23 PM
Thanks James
Don Wohlfarth
May 13 2003, 03:15 PM
Take your time. Years of acculated dirt and debris get packed around the tank and you'll swear someone is lying to you about the removal.
I cleaned the tank surface and found some small oil leaks. Made sure every thing was clean and used fiberglass cloth and resin to seal it. Damn thing was so tight was afraid to try anything else. 10-12 years later and no leaks.
krk
May 13 2003, 07:48 PM
QUOTE(Don Wohlfarth @ May 13 2003, 01:15 PM)
Don,
10-12 years? That's cool! (not too many things last that long unmaintained!)
hm... have we seen pics of your /6? (subtle, eh?)
kim.
Gint
May 14 2003, 08:32 PM
Can comeone please tell me how to get this sonofabitch out? I've removed all appendages and have the tank out of all of the holes in the inner fenderwell (the pic is before attempt at removal). I can't get it more than a few inches aft.
ArtechnikA
May 14 2003, 08:49 PM
QUOTE(ginter @ May 14 2003, 06:32 PM)
have ya tried foul language ? i understand that's required in liberal quantities...
IIRC it doesn't come 'aft' so much as 'down' - but i haven't done mine personally so i can't from firsthand experience...
off to dinner and a Sneak Preview of The Matrix Unloaded... (probably our last night to play fior a while...)
Gint
May 14 2003, 08:52 PM
That's usually the first tool I reach for...
I can't get it down due to the line on the outer side of the tank (the one that goes under the trailing arm and then inboard to the motor). And I don't have enough room to get a wrench in to get the line off.
Enjoy your night off Rich.
Porsche Rescue
May 14 2003, 10:09 PM
My memory says the line you are talking about comes off the bottom of the tank and goes over the trailing arm. It is pretty short (12-14"). Should just drop straight down with the tank. My problem was installing when I learned the hard way that I could not get a wrench in to tighten it. Had to pull the tank again and align the hose, tighten, then re-install tank.
Gint
May 14 2003, 10:40 PM
Thank you Jim, That's the one. Problem is, I can't get a wrench on the small nut (on the line) or the large nut on the bottom of the tank. No clearance for the wrench up in there. And I can't get it low enough past the bottom ridge either.
Gint
May 14 2003, 10:58 PM
Brad?
Brad Roberts
May 14 2003, 11:15 PM
Take another pic for me.. and back the camera out a little. I need to see that whole line. I normally leave that hose attached to the tank and disconnect it from the union for the short line running to the oil cooler. There should be a union that hangs in that 9146 specific "loop" welded to the frame rail.. it has a little rubber ring in it to keep from chaffing the rubber oil lines.
B
Gint
May 14 2003, 11:19 PM
Can't. The camera was on the ground as it is. That's the hose. It disconnected from the pipe and the union that goes in that loop your referring to. The line is only about 10" long total.
Brad Roberts
May 14 2003, 11:22 PM
Gint,
I'm gathering the tank wont come down ?
B
Gint
May 14 2003, 11:23 PM
Will this help?
Gint
May 14 2003, 11:24 PM
Gint,
Won't come down or back.
Brad Roberts
May 14 2003, 11:27 PM
Will pulling the control arm cup off help in any way ?? You will only lose the toe setting which can be done later with 2 tape measures (or even one)
B
Brad Roberts
May 14 2003, 11:30 PM
Check and see if the fender support has been "welded" back on. The factory did a clean job... Joe Hack will have used a MIG welder. It looks like the fender is sucked in right in front of the where the tire would be. This will keep you from getting the tank out. You may want o think about cutting the support and pullin the fender out a little.
B
Gint
May 14 2003, 11:32 PM
Not really. If I need clearance anywhere it's up above the control arm mount. The hose will bend down and out away from the CA. The problem is that union above the ridge at the bottom of the quarter.
That occurred to me. I need to hit the rack. I need to be up again in 6 hours. Thanks B.
Don Wohlfarth
May 15 2003, 08:36 AM
Ginter, Brad may be right that the fender is pushed in a little.
You should be able to move the tank in some type of back and forth motion. If you can get any movement, even a 1/2 in or so, that's a start.
It's just an accumulation of crud that has built up in there that is causing the problem. You can try to wash some of the junk out with a hose, even a pressure washer if available.
Not trying to add insult to injury but the second time you remove it will be a hell of a lot easier.
Pictures...well it's a matter of motivation. My wife bought me a digital camera 3 years ago for Christmas. I've used it twice.
Moving on to computers...I don't do anything more than I need to. Notice my avatar? It's one of those things that just isn't important to me. Sorry.
Gint
May 15 2003, 08:51 AM
Thanks Don. I really don't think the fender is pushed in, although I admit it kind of looks like it in the pic. I may very well end up cutting the fender support. Thr car is going to the body shop anyway. It will be loaded on the trailer Friday evening (when my in-law relatives are all over at the house for a BBQ - free labor!), and Saturday morning it goes to the car wash to get the engine compartment and inner fender/tank area blasted clean. I'm not laying another mit on that greasy oily slimy pig until it's clean.
Lawrence
May 15 2003, 10:15 AM
What's wrong with a MIG welder?
-Rusty
Gint
May 17 2003, 09:25 PM
After I got back from the car wash this morning and removed the wheel, it took me all of 5 minutes to pull the tank. Look for a new thread.
Lawrence
May 17 2003, 09:44 PM
Looks pretty good, brother. Congrats.
-Rusty
