QUOTE(Tom @ Jul 10 2012, 12:25 PM)
For the fuel pump relay to operate, the power relay has to be good also. Both of these get their power from the two 2.5mm red wires from the battery positive. They go to pins 12 and 14 on the 14 pin connector. If you have power at the two pins and none at pin 13 ( this pin feeds the fuel pump), with key to on and pin 86 of the fuel pump relay grounded, one of the relays or connections at the relays is bad. Clean the sockets and prongs of both relays and spread the prongs slightly.
Tom
cool, ill check that out....
